G
guojenman
Guest
works like a charm. scan both and 2D and 3D barcodes and get the information encoded in them. And because it's android, it works with other programs.
*3D barcodes use the same basic principle as linear and 2D barcodes. An image of some sort is applied to a product and then read by a device to log, categorize, inventory, or track an individual product.
*The 3D barcode is engraved or applied to the product itself as a part of the manufacturing process. The bars are not read by variances in reflected light as with linear barcodes but by determining the height of each line. The time it takes the laser to bounce back and be recorded determines the height as a function of distance and time and the character represented by the code can be interpreted.
Doesn't work with Galaxy Tab 2.
