Bards tale data location.
/mnt/sdcard/Android/data/com.inxile.BardTale
That's where it's at on sdcard :)
K.
The save is under (within the folder above): files/SaveGames. You'll see a file composed of letters and numbers. You can copy that file to another device to 'sync' your progress, or to back it up.
