First of all, hi to all of you guys...
I am new to Android app development and I need some very basic help.
Here is my graphical layout.
Here is main.xml file code:
And here is Java code:
This program actually doesn't doing anything for now. Because I get error when I try to run it. I dont get it where is error. :/ Hope you can help me.
ERROR
DDMOS
Code:
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:orientation="vertical" android:layout_width="fill_parent"
android:layout_height="fill_parent">
<TextView android:layout_width="wrap_content"
android:layout_height="wrap_content" android:text="@string/tvNaslov"
android:textSize="25dp" android:gravity="center"
android:layout_gravity="center" android:id="@string/tvNaslov"></TextView>
<EditText android:layout_width="match_parent" android:text="@string/editStatus"
android:hint="@string/editStatus1" android:layout_height="fill_parent"
android:layout_weight="1" android:id="@string/editStatus"></EditText>
<Button android:text="@string/btnKolacic" android:id="@string/btnKolacic"
android:layout_height="wrap_content" android:layout_width="match_parent"></Button>
</LinearLayout>
Code:
package com.test.test;
import android.app.Activity;
import android.os.Bundle;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Button;
import android.widget.EditText;
import android.widget.TextView;
public class Test extends Activity implements OnClickListener {
EditText editStatus;
Button btnKolacic;
TextView tvNaslov;
/** Called when the activity is first created. */
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main);
btnKolacic.setOnClickListener(this);
@Override
public void onClick(View v) {
ERROR
DDMOS
Code:
[2011-06-30 17:35:48 - ddms]null
java.lang.NullPointerException
at com.android.ddmlib.Client.sendAndConsume(Client.java:572)
at com.android.ddmlib.HandleHello.sendHELO(HandleHello.java:142)
at com.android.ddmlib.HandleHello.sendHelloCommands(HandleHello.java:65)
at com.android.ddmlib.Client.getJdwpPacket(Client.java:671)
at com.android.ddmlib.MonitorThread.processClientActivity(MonitorThread.java:317)
at com.android.ddmlib.MonitorThread.run(MonitorThread.java:263)
