RhinoCan
I am trying to help my brother download an app he needs for work. It's called Motive (formerly KeepTruckin) and I found it and installed it, no problem, on my Pixel3 running Android 12. However, my brother's phone is a much older Sony Experia and when I try to find the same app in Playstore, it can't find Motive.
Is it possible that Playstore knows that my brother's phone has a level of Android below the minimum level that Motive needs and that's why it's not showing him the app?
To put it another way, does Playstore show every app it has regardless of the phone's level of Android or does it only show apps that could actually run on the phone because the phone meets the minimum level of Android needed to run the app?
I'm trying to figure out if this is going to force my brother to upgrade his phone or if there's some special trick he needs to use to find Motive and install it on his phone.
