batteries problems
masmie
why my xperia x10 battery so hot very quickly when i'm still using it? when i charging this battery even it still hot why the battery not charge to 100%?
This can be a tricky question, whilst the handset will get warm when in use I would not say that it should be hot. In regards to not getting to 100% you may not be aware that the handset stops charging when it hits 100% and will not start again till it drops to around the low 90's from memory.
Tq sam-seanswers.
My phone battery still not 100% full after charging even the battery icon shown the battery is less before. It shown full only my phone was cold. I don't know why my phone battery is hot/warm when i use it and the battery is low very fast.
Sorry I am not really following you, are you stating that the handset is not charging and is in fact losing charge whilst connected?
Only charge phone with the Sony USB cable, and it should charge to 100 percent. If your phone is running a lot of apps, it might have a hard time staying at 100 percent. If I am running 20 apps at once, (use a Task Manager and see how many apps are really running....or use running applications)
Charges better when plugged into a wall outlet compared to a PC or laptop.
About Phone->Status->Battery Level
