Battery App
angldvl81
Android Expert
I have an Evo and am looking for a battery monitor that doesnt consume alot of battery. I'm currently using Batteryminder and according to the Android Assistant, its consuming 9% of my battery.
soooooo, if anyone knows of a good battery app out there, i'd be very thankful for the recommendation!!:)
Juice Defender all day. I am telling you when you leave it running you will notice a huge difference in battery life.
i downloaded that yesterday so i'm still playing around with it. i havent noticed a percentage in the status bar option though. so far i havent noticed a difference. in the 50 min from taking my phone off the charger and arriving to work, it dropped 8% and that was doing nothing on it at all.
Use Battery Indicator if you want a battery monitor.. its legit; simple and to the point...
