JamesChatz
Hey,
not sure if this is the right place for this thread but I'm having a few problems with the battery in my Portal.
Battery would only last about 6 or 7 hours from 100%, with GPS/bluetooth/wifi etc off. Managed to narrow the problem down to something syncing data with the background data setting, turned that off and it seems to be back to normal.
Is there any way I can find out which app (I presume it is an app) is causing the problem? It's a bit annoying to have to keep turning it on and off everytime I want to go to the market place. I know there is the menu in settings, but it doesn't really help me when it just says "Android system".
Cheers for any help
Cheers for any help
