Hi everybody.
I have this problem.
Since some weeks ago, I found problem with battery draining, so I bought a new battery.
When I try the new battery I found out the problem was not the battery, the draining persist.
I have no application, no wifi no bluetooth and so on.
I have 2 batteries.
1st battery now is fully charged and android says 4200mV. Verified with an electrical tester, and it reads 4140mV (quite similar)
2nd battery completely empty (phone don't start), but electrical tester says 3000mV.
I try many times to wipe battery stats.
Effectively when I confirm battery start procedure, no confirms appears on display (eg: when I wipe cache on display is shown: wipe cache completed).
What do you think?
Thanks in advance
I have 2 batteries.
What do you think?
Thanks in advance
