Does anyone know of a wall charger that will fit the extended battery? I have two extended batteries and the stock battery. I've never been able to charge them all. Need a wall charger asap but i want to make sure the extended battery will fit.
The battery is the same height and width only the depth is bigger so it should fit in any standard battery charger for the bionic. The contacts are exactly in the same place for both batteries so I dont see any isses.
moto battery dock holds the extended. i had two of them but returned them both as they wouldn't charge the ext batteries to 100%, even after more than 9 hours of recharging time. I've seen one other commenter saying the same thing, but others report their docks charge their batteries fine. How I could have gotten two bad docks in a row seems pretty far fetched, if u ask me.
