Can't read the charging rate on the charger that came with the phone and intend to purchase a 2nd charger. Asked in a few stores and no one knew the correct rate.
Could not locate a specs section in the lengthy manual and would like to know the best/max charging rate for the standard 2500 mAh battery, as well as the recommended max size battery that doesn't require a case enlargement.
Any knowledge as to where this information can be found would be appreciated.
