Unisaur 64
How Often Should I Charge My Gadget's Battery to Prolong Its Lifespan?
After reading this article, I have some questions on how best to prolong the life of my phone's battery.
My Situation:
I have recently bought the HTC Wildfire S, before using it, I charged it until it was full, and have been using it for a little over a day ( I have switched it off in college).
Should I do a full charge/discharge cycle ? How do I do that, exactly ? Do I charge for 8 hours, or just until the battery is full ? Should I leave the phone turned on while charging, or turn it off ? Should I also let it discharge through natural use ?
Any other battery charging tips that the article may not have mentioned ?
Thanks in advance...
EDIT:
I've also lurked around a bit and found a helpful post from one of the mods, lunatic59...:
Should I leave the phone turned on or off while doing step 2 ? This method seems to contradict the article somewhat, so which one should a go by ?
My Situation:
EDIT:
1. Let your phone drain to nothing (phone shuts itself off)
2. Charge the phone uninterrupted using the a/c charger, not the usb cable.
3. When fully charged, unplug and reboot the phone.
4. plug the phone back into the charge and shut it off. Continue to charge for at least an additional hour.
5. Reboot phone one more time.
