Christopher Clayton
I have just read that I should not use my Mi Note 7 phone while charging it as it can damage the battery. Is this correct? There are quite a lot of 'myths' around battery charging and use, is this another?
well just keep in mind that the longer it charges and the more time you charge the battery the less of a life span the battery will have. it might not damage it now, but it will wear it out faster. now we are talking about a tiny amount each time. it is truly a small amount, but it can add up.....so keep that in mind.I have just read that I should not use my Mi Note 7 phone while charging it as it can damage the battery. Is this correct? There are quite a lot of 'myths' around battery charging and use, is this another?
My observations are that if you can see a cover which can be removed easily (e.g. Samsung S4) there will be an easily replaced battery.how easy is it to replace the battery in a Mi Note 7 and other smartphones
