Anker battery.
Most recommended battery for this phone.
Is this battery an extended one and is it the same size as stock and can fit without a special case? Got a direct link for it?
I actually got an $8 cheapo battery that comes with a back cover (from ebay). It is supposed to be 3800mAh but is actually around 3200-3600mAh (Chinese batteries are notoriously over rated). Anyway it will last a whole day with net intensive apps running all of the time. And for $8 w/ free shipping...
Search on ebay. They tell you which ones fit using the oem back cover. There are a couple.I used to buy extended batteries but I'm more concerned with keeping a good case on my phone ( otterbox ) so extended batteries that fit in like stock are what I'm looking for
I bought an Andida 2300mAh battery off eBay. The battery fits into my phone with the stock back cover and I have it wrapped in an otterbox case. Battery life with it is noticeably better than the stock 1800mAh. 2300 may be the best you can get without an extended back cover, but dont quote me on that.
