Help Battery condition unknown
secretLOVER
No clue what's going on here. I battery swap between stock and extended. Tried resetting and nothing happened. I am now draining completely to try and reset.
Anybody else run into this? I will update...
do you have a aftermarket battery? Mine did that when I purchased the wrong type of battery on ebay
Nope. Its the stock battery, and only the stock battery, that does it. My extended works fine.
Google indicates it being water damage but it wasn't near water when this started.
just got off the phone with them. Seems i have a defective battery that's still under warranty (bought end of Dec) and i can just take it in store to get a replacement.
Just updating in case anyone searches.
This occurs on an after market battery I just received....
What's interesting is my battery widget reads the battery fine, but the status bar shows the same grey battery indicator with !....
Also.... LOL!.... I lose all audio notifications... no sound at all from calls or notifications...
Very strange...
Lego
all this started with an aftermarket battery? is the battery compatible with the rezound? where did you purchase it from? it might be a wise idea to purchase the correct battery that vzw sells and see if your phone functions normally once its plugged in, and if not, you may have something else going on with the device
I currently have 4 batteries...
The stock battery - Which works fine...
2 Hyperion (after market) - Which work just fine...
1 Off brand (after market) - which gives me a grey battery and ! in the status bar and kills all the rings and sms notifications...
Strange.
