Battery cover replacement?
TheAtheistReverend
Anybody want a peanut?
The clear plastic on my battery cover (over the camera) has a crack going right through the line of sight for the camera.
Anyone know of a good place to get a (hopefully cheap) replacement rear cover/battery cover/phone back?
I had the same problem. Only place I could find one reasonably priced was ebay. Just search droid eris battery cover & you should find it. I think it was about $15 with free shipping.
Yeah, so far that is the only place I have found one.
But I will never buy on eBay again. I have been burned 6 out of the seven times I bought off eBay, and the "good purchase" was the most complicated, long, drawn out rigamorol with a semi acceptable outcome. I don't ever want to shop through there again.
Thanks tho-
