Root [Battery] Crysis eVolution - New easy installation method [17.04]
Crysis21
Hello Guys
I have designed a glow circle battery for my own use, but I decided to post it here so you may use it in case you like it :)
If you like my work, please consider a small donation to help me continue developing.
Change log:
17.03.2011
-Reorganized the threat so everyone could easily mod his own framework. Follow the new installation instructions
-Added CWM file only with script so you can use it with your framework file safely.
-Uploaded new reorganized image packages.
14.03.2011
-added new charger images. -- Beams -- ( i might rework them in the next days) --
-added missing images for full charge and so on...
-I will modify tomorrow morning the threat, with new reorganised files cause it became a little confusing :D
03.02.2011
CAUTION:
Flash only if you have DOC's ROm, because some users stated that on Darky they had problems. Not sure why, because it should work - they're both deodexed roms. Do a BACKUP
-Added CWM files for V1, V2 - with percentage and clear at charging
-Working to a new animation for charging, a lot better than this one, but I can;t tell you when it will be ready because I have a lot to work for my school
02.02.2011
Finished creating charging icons and XML editing for animation. I Added two versions of the framework:
-Version 1 : loops the circle animation continuous, without showing the current amount of battery after each loop
-Version 2 : Shows after each loop the amount of battery
01.03.2011
I just created another battery with life indicators on the margins:D
INSTALLING INSTRUCTIONS
1. Download 3 packs: one with images of the battery (batt1 or batt2), one of the chargers (Glow, or BEAMS) and one of the charging animation images (with percentage and without).
2. Download CWM_update.zip
3. Place the files from the battery pack and charger inside your framework-res.apk file, in /res/drawable-hdpi.
4. Place the file from charging script inside your framework-res.apk file, in /res/drawable
5. put the modified framework-res.apk file inside the framework folder, of the CWM_update.zip.
6. Reboot in CWM.
7. Clear cache.
8. Clear Dalvik.
9. Flash the file.
10 Reboot and enjoy​
Previews:
New Evolution Battery
Glow Charger
Old Evolution
Beam Charger
DOWNLOAD
Battery:
New Evolution: Multiupload.com - upload your files to multiple file hosting sites!
Old Evolution: Multiupload.com - upload your files to multiple file hosting sites!
Charger
BEAM Charger: Multiupload.com - upload your files to multiple file hosting sites!
Glow Charger: Multiupload.com - upload your files to multiple file hosting sites!
Charging Script:
With percentage: Multiupload.com - upload your files to multiple file hosting sites!
Without percentage: Multiupload.com - upload your files to multiple file hosting sites!
CWM_update.zip: Multiupload.com - upload your files to multiple file hosting sites!
