draysdroid
I was very unimpressed with my DRMs battery so I did some research into Li-Ion batteries and installed the System Monitor app on my phone as well. I discovered a Li-Ion battery has a cutoff voltage normally in the range of 2.7 - 3.0 volts. However, mine is cutting off at around 3.6 volts, leaving about a days worth of power unused. This explains why I was getting only about 1 day of use out of a full charge.
Do I have a defective battery or will this improve over time? I have had my phone since February 16th.
