Battery Drain Analyzer
webiky
Requirements: Android 2.2 or higher
Overview: Increase your battery life.
- shows you which application drain your battery most (ONLY FULL VERSION)
- shows battery status in notification bar (optional)
- shows battery status in widget 1x1 (optional)
- shows battery level changes in time for today
- shows battery life statistic for last 30 days
- notify you in case battery level is bellow selected level (optional)
More Info:
https://sites.google.com/site/androidapplicationsmichals/battery_drain_analyzer
