Help Battery drain caused "partial" reset - how do I fully restore (rooted)
I know it sounds improbable......but my wifes phone was at 3% battery the other night.
She says "whoa I better get this thing on a charger"
Then a phone call came in....after about 1/2 a minute the phone shut down.
She plugged it into a charger and waited a few minutes.
The phone would not turn on until the orange charge LED stopped blinking.
Once she did get the phone to turn back on - it had done a "partial" reset....sort of.....all apps were gone from ALL the home screens....wallpaper was gone.
Phone is rooted.
We have both Titanium and ROM manager on the phone.
It's been a long time since I've had to do a restore.
What's the procedure to get the phone back to the way it was prior to the reset ?
Is it through Titanium ? or in Recovery mode ?
Thanks for the help.
Dan
Phone is rooted.
Dan
Go into recovery, select the back up/restore option, restore your latest backup. (volume keys select options, power button chooses). You may then have to use titanium to restore any apps you didn't have at the time of the backup.
