Battery drain
  • Start date Start date
A
Android Question
Guest
My Samsung Note 2 started having severe battery drain about a week ago. 100% battery only lasts less than 1/2 a day. reset the phone, did a factory reset, replaced battery, performed another factory reset. Battery life is a little better but I used to get 2 days on a charge now I am lucky to get 7-8 with the phone being idle. Can anyone help?
[FONT=&quot]Hello and welcome to Android Forums! :)
As you have said that you used to get 2 days on a charge, it sounds like you may have a rogue app that is causing the battery issue. You could try uninstalling all apps you have installed recently and then, one by one, re-install your apps, to see if you can identify if there is a problematic app.
If you sign up, you could head to Samsung Galaxy Note 2 - Android Forums to see if any of our members with the same phone can offer any other advice :)[/FONT]
