M
Mycroft797
Guest
The Samsung Galaxy S III Mini that I currently have is actually handed over to me by my mother, who had used it for over a year. She used to call a lot.. And now the total call time is 637 hours. The original battery had many issues, it would immediately get switched off when the battery was at a normal level, sometimes even when the battery is at 99 percent. So she bought a replacement battery and used it. That is the current battery in the phone. But there has been one problem since the first day the battery was used. It would drain from 100 % to 75% with No usage. Then it would drain normally. Nowadays it has been having inane battery life issues.
The battery will be at about 70 or 60%. Today morning I used it, it came down to 40%. AND, I put the phone down, picked it up after about 5 minutes, and the battery was at 28%. This happens all the time. Normal drain while usage, extreme drain after you put the phone down. I looked at the battery usage status and Android OS and Android system are the drainers. Please help.
