Hi there folks!
So I've read over at Lifehacker (since I can't post link you can search "lifehacker + battery" at Google and the first link should be the article I've read) that you should discharge your Nexus 5 once a month to keep it healthy and optimized.
So my question isn't about why, that is already answered in the article, it is how I should do it. Is it okay to use a battery drainage app for discharging it once a month or should it be discharged by my natural behavior (i.e. I shouldn't don't use an battery drainage app)? If it's okay to use an app, does anyone have any recommendations about a specific app? I've tried one app that discharged about a 1% per minute. Is that reasonably fast or should I try other ones which will do the trick faster?
Since the reason for doing this is for optimizing the phones estimation of remaining battery power I would guess that using a battery draining app creates a skew vision of the battery power for the internal systems of the phone.
