Help Battery Draining Issues
D
Deleted User
Guest
I'm running the venir rom and I've been having battery problems. I started out the day with %100 battery and spent 30 mins browsing the internet it only went down to %95 which is normal, but I put my phone away and two hours it went down to $60 then 4 more hours it went down to %20.So obviously something was running in the background ,but I killed all my apps when it went down to %60 just be sure, but it kept dropping. anyone have an idea on what to do?
I would make a guess it has a lot to do with the "venir rom" you installed. Did you have the battery issues with the rom that came with your phone?
No, before I had no problems with my battery it just started when I got this ROM and there were no foreign apps installed..
yea, but this rom has amazing customization options and removes the annoying touchwiz. Would a custom kernal save any battery life?
