Help Battery Draining Too Fast
ttcapt46
I don't know what's wrong. The phone just loses its battery to fast.
In all your screenshots, I notice that you have little to no signal. Is that common for your location, or a recent change? In any case, a phone struggling to hold a signal can have very fast battery drain. If it's related to your location, I'm not sure what you can do other than look at a booster, or put your phone in airplane mode to save battery until you get to a location with better signal strength.
it looks like the cause might be your mobile signal it looks like your having trouble getting a fix on a good signal after about 30 or 45 minutes. indicated by the red and yellow areas. Try updating your PRL
Actually it's at my school. In my school there is no signal, they blocked it. So basically everyone uses the schools wifi. My crappy windows phone and iPhone 4S didn't go down this fast. And I played games on those phones
Your crappy Windows phone and your iPhone didn't do true multitasking either.
Turn off mobile data and and any other radios you don't need.
If you don't need to be taking phone calls (school yeah? lol) put it in airplane mode, then turn on wifi if using that.
Turn off airplane mode when you need to use the phone signal.
Alright will try it out. Thanks
