Help battery draining very fast
zhun2u
hi, I was charging my phone from a wall outlet. When my phone reached 100%, I plugged it out. the moment I plugged it out, my battery status immediately dropped to 11%. Can anyone please help?
Hi zhun2u. Welcome to Android Forums. The only time I had a charge problem such as you describe.. it was my battery going south. If you have another battery7, it would be a good test to try charging it. If your battery is old.. you might check into a replacement.
I hope the problem is as simple as all of that for you. Perhaps another has additional advice to offer. Best of luck to you and thanks for using these forums.
