TouchyFace1
Seem worked but ate up 2 bar of battery for like 2 hours later and i really have problem here because my display tab on battery use setting in phone and display still at 98% if I darken brightness tone down on my phone and still high at 98% of using battery on display tab? Cell stand by only 2% and time without signal 2% too and can someone please help me fix with display bright adjust in order to reduce precentage usage on display and fix this *bleep* issue!!!
Display taking TOO much juice almost 99% and please help fix that, UPDATE: Time wihtout signal 8%, 98% of the battery is used by Display, Battery used by display and backlight at 98% and i tried 3 time by toggling off and on airplane mode and seem not help anything but its seem effective little bit better but not that lot and the question is: How can I reduce the battery usage precentage for display? Im currently at 98% precentage usage that drain the battery by display at 98%!
