Help Battery drains alot when on standby
have you tried using the built-in task mananger before you stick it on standby? Sometimes the battery will drain fast no matter what state it's in if you don't end the running apps.
Yes, i have the habit of ending all the background apps before putting the phone to sleep.
turn 4G off..its the only reason....the background apps make a bit of a difference but mine was doing the same..i turned 4G off and its made it better
did this fix your issue?
yeah it did quite a bit, id charge my phone to 100% then pick it up an hour later without use and its on 80% then i use it and it drops to 70 rapidly...the 4G sucks the batter power..ive also been turning off GPS cos its not really needed plus its quick to turn it on from the notifications bar when you need it.
these phones are quite powerful so will suck the battery no matter what..i never look into standby hours or talktime hours because they're pretty much always bullsh!t.
mine last for 12 hours and still has 40% left under heavey use
mine is on 4g too and has gps on a lot
damn!!! i just barely got a day but my emails are always updating and my brightness is set to high with no power save on thats why i turned gps and 4G off
