Samsung Galaxy A02 - Android 11.
After testing several apps I found the best one for my needs to be the one in the below link for camera blocking.
https://play.google.com/store/apps/details?id=com.donotspy.app&hl=en
It is the only one that was able to block the microphone and camera in all apps and it will automatically enable the mic when making or receiving the mic on any app.
It has a battery saver option. But I don't use it because it makes the app unstable and it would sometimes quit on me for no reason. I also disabled the device optimization for this app from settings so that it works until the battery reaches 0%.
The app would work perfectly without any issues at all. Even it is left undisturbed for 10 days. Yes my phone can last 2 - 3 weeks without recharging.
If at any moment I restart the device or the app closes and is reopened or I toggle the switch to off and then on again then the battery would drain to 0% in just a few hours. It would only stop draining after the recharge.
I would like some recommendations to stop that from happening. This issue did occur with other apps. But I don't remember the apps that did the same thing anymore.
