Battery fix??!!??
um yeah.. i dont if this is a fix or wat...
so i decided to unroot my phone because wanted to sell.
so i unrooted my phone with gingerbreak, then i tried a factory reset but i could not because of cmw.
so re rooted my triumph and to my surprise...
After a couple hours of music playback through the phones speaker my battery did not drain completely. like it usally does. so i played a movie then check my battery only 10 percent was gone with a hour and a half movie....
getting to the point i dont how but after rerooting my phone i got better battery from my triumph...
What do you guys think?
In the process, you probably altered the table that maps voltage to % remaining charge, i.e. the battery/charge calibration table.
what brand screen do you have? screen on rapes battery. doing nothing and just having the screen on, i doubt i'd be able to get 1.5 hours off a full battery
it's until you install whatever app and all goes to shit. for me, words with friends causes my battery to die in 8 hours. of course, everything else i have is a background data pig as well. i disabled juicedefender for a while and went through 3 batteries a day. just turned jd on again and now am able to get a day on a charge again.
