Hi there,
The phone battery gets heated up a lot. When im playing games, it goes uptill 105....is this normal....also if i play games, the battery drains by 25% in jus 15 mins...are all others also facing the same problem...Please check and let me know...as for checking the battery temp you can use the battery life widget.
