Help battery help and temp
So, i have tried most of the battery fixes on the forums, but my battery drains super fast. disabled talk, did the cdma fix, closed all possible running apps, turned off autosync and the battery still drains. It drained 35% in 30 minutes on airplane mode. I have the battery indicator app installed and the current temp is almost 45 celsius. Is this too hot? My phone is currently charging.
I was getting frustrated because my battery life was not good and it seemed like my phone was running hot. But, it seems like I have my battery issues figured out now and my phone no longer runs that hot. Thanks for your help.
