Help Battery help?
mills23
Android Expert
What is in here I can turn off? My battery is dying before 3pm all the sudden.
Run your phone in "safe mode" for a day see how your battery is with all your installed apps not running... That way you can tell if it's one of your apps or the phone itself
(Safe mode = reboot, hold down button while rebooting)
I checked all the running apps and every one that I turn off just comes back on. It looks like the android system or (whatever that's called at the top of the list) is using a lot
disable them.. don't just turn off/close/force stop. . it will really re-open in time..
disabling the service/app will stop the app from running unless you enable them again..
