battery increments changed with jelly bean?
My battery now drains at 94 percent instead and the increments are way innacurate. Is there a way to change this? If not can there be another update that will change this because it is annoying me
I am certain they adjusted the way it looks at the battery. Give it a little bit of time and it will readjust itself and become more accurate. Whenever you first do an OS upgrade it takes a bit for it to even things out.
