Help Battery indicator led doesn't turn off
tzvyl
Hi
Since I updated my sony xperia s to jelly bean, the battery indicator led doesn't turn off when battery is fully charged , it used to before the update.
Now in order to turn the led off i have to restart the phone.
Actually from what I have seen with a few of the handsets here on Jellybean this is standard to this firmware. The only time you will see different is if you have a notification pending in which case this will take over the notification light.
Thanks for the answers
The led does change to represent other notifications , but when you turn those off , the green led turns back on until you restart the phone.
It can't be standard if everyones phone doesn't do it.
I might have been a little misunderstood ,I know it is standard for the indicator to show that the battery is fully charged (led shows green colour).
Before the update ,when I unplugged the phone, the led used to turn off,
now it keeps on forever.
Thanks for your help
Led stays on my phone 2 after jellybean update... But not all
time, only sometimes, then I again plug-unplug charger and
light go of, or restart phone...
I've had no issues after installing Jelly Bean. The light is on when charging, turning the green when full, and then when I unplug the phone, the light goes out as it's always done.
Which firmware are you using? I'm using the "World" version.
I don't know which firmware I'm using, I have no idea where can I find it, I don't see it in the "information about your phone".
I have the very same problem.
Have you checked your Battery status when the led does not turn off?
Mine shows that the phone is charging, however it's been unplugged from the charger. :mad:
