my phone losses a lot of battery when its in idle and no its not the 3g network cuz I have an app that turns it off why is my idle in 53 percent
Because the battery has spent 53% of its time in idle... If your battery percentage is dropping by a whole lot its nothing to be worried about.
yeah but about a week ago I used to go to school for 7 hours and I go fully charged and when I get back home my battery used to be in 93 and up percent I don't know why my phone is losing batter when the screen is off
If your on stock and unrooted, then that's not bad because stock isn't the best battery saver... And the reason that battery drains while the screen is off is because the cpu is still working, the radio is still working, as long as your in a good service area though it should be a slow drain. I can get vertually no battery drain with my phone in idle, but as soon as I wake it up, my battery begins draining like crazy (mainly cuz I always have my brightness up all the way, and use data). I really wouldn't worry about it unless you start losing more than that especially with data off...
I'm rooted and my battery was not draining like this before
What apps have you installed since when you were getting better battery life if any?
fandango' weather app ' and I put the weather app as a widget and that's it
what is idle anyway?
Idle is just when the phone isn't doing anything. When the screen is off and its just basically sitting there.
than why its losing power and why is the percent so high in phone idle?
What are the other percentages? The percentage just means that's how long it has been in idle not how much battery is being drained by it.
phone idle 51 percent cell stanby 48 percent and display 3 percent
Hmm well then I don't know what is draining your battery quicker. Those seem right for being sleep with nothing running... Did you apply a live wallpaper by any chance?
How is your cell signal in that area?
Can you check your time without signal as well?
time without signal 15 percent
That might be why then. Time without a signal means during that time the radio is constantly looking for VMs (well technically sprints) network to be able to connect to it so it working harder and using more power...
i turned my phone of and i turned it back on yesterday and today its 10.20 am and i unpluged my phone at 7 am and its still in 100 percent![]()
