Help Battery issue?
Screen 56%, Android OS 20%, standby 7%. media server 3%, Tango 3%
I'm wondering what media server is? Also i never even opened tango in like 3 months? Android OS is apps? I didn't open 1 app, only texting which took around 4%. and this was overnight basically for the most part. Start at 100% to - 65%. Just wondering why the android OS is so high
I am not sure if this is Android OS or Android System, but one of them is the base from where the battery drains. For example after you charged and you haven't done anything with the phone, Android OS (or System) would actually start from 100% of battery used.
After you start using the phone, or if any apps start running in the background, the battery use percentage will start distributing around. Media Server is things like your music/video player. Dropping to 65% seems rather high, but if you are using the phone (hence the high battery usage for screen), then it doesn't seem so strange.
Cheers
Cheers
Out of 12 hours the screen was on for 1hour10mins.... ? I don't think that seems right
You watching a movie or something? Screen would usually take up the most battery if you are using the phone. Last only about 3 hours or so of video/movie watching.
Your phone new? Battery also gets better after a weeks use.
