ardchoille
Android Expert
That doesn't make sense because my battery life increased when I installed it so that means if I take it back off I will only be in the same boat as I was before. I have no issues with my battery now so it works for me. Like I said, I was just sharing what works with my device.
You're sharing what works for your particular device for the way you use it.. no problem with that. However, we must remember that what works for one person may be troublesome for someone else - especially if that advice is contradictory to known system performance, as your advice was. No offense intended.
Try this, uninstall your cache cleaning app for a week and see what happens. You can always reinstall it later. You may just find that you don't need it.
