Battery Issue
  • Start date Start date
A
Android Question
Guest
nexus 4 battery keeps getting low after 3 hours of use from when fully charged. What do I do about this
Turn off everything you're not using - wifi, Bluetooth, GPS, etc.
Keep the screen intensity lower.
Shorten the screen timeout.
Look at the battery settings to see what's using most of the battery - you could have an app running in the background that you don't even need that's causing this.
