Help Battery Issue?!
A_heych
I'm on Cyanogenmod 11 Snapshot M5 and I have recently have had this issue with my battery where it would drain fairly quickly throughout the day and after I put the charger in, after a couple of minutes it's at 50 or so percent? So how does the phone die if there is actually some juice in the battery? Help would be appreciated, thanks in advance.
Hello and welcome to the forums. You have that problem with cyanogenmod mod roms these are unstable builds .I also have had the problem there isn't no fix for it until the next build . you think that's funny did you turn off the device and plug to charger and discover it was at 85% .:eek::D:what: yes mines died and when I plugged it up to the wall charger it displayed 85%. Can you say freaky
