gnipgnop08
Hi all. I'm new to the forums. I've been reading a lot about battery optimization (including Caddyman's post from 2009) but cannot seem to pinpoint my issue. I'm running 1.5 and do not seem to have the dreaded SMS bug; however, I am still experiencing high (75-85%) awake time levels with little device use. I have just a few apps installed so far, so I think I can isolate the culprit(s) with your help!
I turned off auto-backlighting and set the brightness to 25-30% with a 30-second timeout. Turned off haptic feedback. Turn off Wi-Fi, GPS and BT when not in use.
I'm still in the process of conditioning the battery; I'm on my second full charge after two complete drains and observed significant improvement from this...until...
I installed YouMail and gmote. Prior to the installs I was down to about 20-30% AT when using the device *very* sparingly (1-2 two-minute calls, a couple texts over the course of a few hours on a full charge).
Settings
YouMail: SMS notifications turned off, polling disabled
gmote: doesn't seem to be a feature to log out/off...don't know if this is automatic when exiting app.
Apologies for the lengthy post. I've just observed that most folks willing to help will ask for more info anyway.
Thank You
Settings
Thank You
