brianbrod1
Member
Any and all help would be nice! Getting about 3 hrs between charges with moderate use. Showing display as biggest user. Nothing appears to be hogging battery that I can see
Any truth to battery needing break in period??
Have used all options in smart action. Should I try something like juice defender?
I hate to say I'm having similar problems. Have to recharge after 3-4 hours of moderate/low use. The usage stats say display is the biggest hog for me too, but seriously this is pretty much out of the box and I did the necessary SmartActions too (do like this feature very much).
I guess on Monday I'll go back to the store, and see if I want to exchange it for another RAZR or I may as well take a look at the Nexus too, even though the no SD card was a deal breaker for me originally.
3-4 hours is pretty horrendous. is 4G spotty where you live? maybe try shutting it off for a day and see how battery life improves?
there actually were a few people who were having serious battery issues and exchanged their phones and have had much better luck with their new razrs. i think sean76 might have been one of them - he's pretty active, send him a pm maybe...?
we'd hate to see any razr owner switch to a GN just as much as those guys would hate to see one of thier own pick up a razr![]()
Set your smart actions (disable all others) like this:
Triggers:
Display: OFF
Charging: Not Charging
Actions:
GPS: Turn off GPS
Background Sync: Disable
Wi-Fi: Off
Cellular Data: Disable
Bluetooth: Off
If you still get < 3 hours, you have a defective phone. I've had my phone off the charger for 10 hour and still show 90% battery remaining.
Your phone will still receive calls and texts.
I'm sorry but do you even use your phone?I'm sorry but do you even use your phone?
Yes, actually I do. However, I'm not glued to it like a lot of people are.
Obviously, I haven't used it a lot today. I was just trying to get a baseline. From that point, you can create smart actions to help manage the battery. The first goal is to see if the device is defective or has a bad battery.
One thing to think about as well, I work on a computer in an office all day long. There is no reason to have the phone sync and burn battery all day long. I typically use most of my battery life in the evening when I actually use the phone.
For some this is an option, but really it is just turning off options that to me is taking away the point of having a smartphone in the first place. I have several businesses and need and use email push at all timess. I have always left my phones on "performance" mode and really battery life has never been that bad on any of my android phones. If you use a high powered app extensively or have the screen on all the time then yes, you will burn up battery in a hurry.
My battery life is terrible....This is my second one, I've had it since Tuesday! The way I look at it is this way...
If your on your phone quite a bit, and your in a 4G area, get ready for shabby battery life! I happen to think the culprit to my bad battery life on here is Beautiful Widgets...
there are already a few threads about this for you to search for, but a few things real quick...
turn down screen brightness, turn off wifi, turn off bluetooth, turn off gps, have emails check less frequently, have widgets update less frequently, etc.
