Help Battery: Keep it up or bring it down
mrgou
Hi,
For every device I get, I feel it's different. So on a Galaxy S2, should I wait until the battery is almost empty before recharging it (like on the very first charge), or should I charge it as often as possible?
Thanks!
Raph
Put your device on charger while you sleep and relax and do not worry about it. Do NOT run your battery to dead as that WILL shorten battery life. If your battery is not making through the day, top off as required.
Nothing you do when it is new will greatly change the way your battery will perform. Just use it and enjoy. If not you are going to worry so much you are going to ruin your new phone experience.
