I like this app because instead of giving the system battery percentage, it gives the battery percentage based on the actual amount that is remaining, since the first 10% of the battery is used much faster than the rest of the battery. Works fairly well, and tells you when it is working accurately or whether it needs to be calibrated more. Only improvement I could suggest is maybe make a notification/status bar icon as well.
