Help battery level widget application - shows time left
austriker
Hi,
A few months ago I downloaded a widget that showed the battery charge of my g1. This battery widget was different though, because instead of basing its levels on what the android system was said the amount of time left in the battery by configuring while you are using the phone so it is kind of personalized for each user. Most apps just tell you the charge level (ie 20%), where this one told you how much time was left (ie 20 minutes) based on your usage. I remember it told me to run down the phone from 100 to 0 a few times for the widget to configure..
Anyone know? or does anyone know of a similar widget for free? (it was free)
thanks
so for future reference it is called: battery left (who would have guessed this?!). I searched for battery left icons and it came up..
thanks everyone for your help
