Help battery life 3-2 hours
can someone help my motion's battery life is only 2-3 hours when not in use 15 at most when I use it
things wrong with it that might affect battery life
red "I got wet indicator"
crack screen
root
4 year old battery *this need be it*
*update*
also incorrect battery percent
example its at 29% plug in charger wait 5 seconds check and its at 69% also plug in charger its at 79% takeoff charger put back on back on charger then repeat take off put back on then its at 49%
Aged battery can supply incorrect and intermittent voltage information to the phone, buy a new battery ASAP.
cant because I broke unless somebody would like to sponsor my youtube channel (bossgamer102) by getting my a new battery *hint hint wink wink*
