I don't see much difference on my RHD after JB update. Actually I feel it's slightly better after JB.
One thing to note is that I disabled location report/history in google map setting. If you use Google Now, it will automatically enable location report/history in google map which is extra battery drain that didn't exist in ICS. This isn't easily noticed and it's giving impression JB is worse on battery.
This worked for me very well today actually. Looks like I saved around 10-15% battery. But I had to disable it, I need constant weather updates during the day since I move from city to city a lot. It's unfortunate, but thank you for posting the solution.
Glad that it helpled. That tip is only for minimizing battery drain from google map and now. Weather widget works fine with city location if google location service is checked in the main setting menu.
Mine is worse. I wish I stuck with ICS and rooted. I could get over a day, now I get about 18ish hours.
I'll try this and see how it works tomorrow.
