iceviper22
I have a Razr Maxx HD and after the 4.4 update, battery life has gone to crap. Anyone else having the same issue?
At first yes, battery was rapidly depleting. I have since done a FDR and more importantly started examining where the battery was being eaten. I found most of it was screen and then after I got the brightness under control it was WiFi. I then set to turn off during sleep and then set apps not to use WiFi when off. I am not at 89% left with 1 day and 5 hours on battery.
My battery life is noticeably worse after the update.
Previously my phone would go 2-3 days before battery got down to ~25%.
Now I'm at 25% after a bit more than 24 hours.
I keep WiFi off 99% of the time.
I haven't changed any settings besides vibration duration, and I don't really type a lot.
Any suggestions on what else to try? I have not done an FDR yet because I really don't want to blow away all the data on the phone's memory.
Google, do you read these forums?
YOUR NEW OS VERSION IS CRAP!!!!!
This is no different from most OTAs, but in this case, we made a major jump from JB to Kit Kat (4.1.2 to 4.4.2). So, usually, battery life isn't the greatest when you just take the OTA with all your apps still installed.
I always do a complete wipe of the system before taking the OTA. Usually, I FXZ back to the latest stock before the OTA and then apply the OTA manually.
With Kit Kat, my battery life has been as good if not better than under JB. As much as people hate doing FDRs, they are a good thing, especially if you've been running the previous version for a long time. So much gunk gets built up that doing some "spring cleaning" once in a while is always a good thing.
Oh, and I doubt Google reads these forums. They have more pressing matters at hand, and actually, Kit Kat is the most stable yet. Before, under JB, I was getting a lot of slow downs. With Kit Kat on this phone, it's like a brand new phone with better hardware.
I never use that mode, my daughter does but she uses the phone a lot more than I.
Yes. What s motocare and how do I get rid of it. I have it turned "off" but it is still sucking power like a fiend.
