Help Battery life extension options
Montalvo
I'm struggling to extend the battery life on my MyTouch 4G. JuiceDefender has helped, as have disabling network connections when not in use.
But I've got a problem I haven't been able to solve. After syncing my Outlook with my gmail calender, the notification alarms cause my phone's screen to turn on every five minutes until I dismiss the alert. For alerts set for daily events, this starts at midnight when I'm sawing logs. If I forget to have my phone plugged in at night, I wake the next day with an exhausted battery.
Under Settings/Reminder settings/Set alerts & notifications, I can turn the alerts off but if I select either Alert or Status bar notification, I'm stuck with this continuing "screen-on" problem.
Can anyone suggest a solution?
Set your timeout low? Itll be annoying when you want to use it, but if you need the battery life its worth a shot
