Battery life for samsung galaxy s3
Mikewen07
Hi i just bought a samsung galaxy s3 and i noticed that the battery drained fast. I charge it for 4 hours until it fully charge.
Thanks
Thanks
Everyone has that problem, you can try these steps unless you want to buy a bigger battery.
1: you can try an app like Easy Battery Saver from the Playstore.
https://play.google.com/store/apps/details?id=com.easy.battery.saver
2: When not using turn your brightness down, Gps off, Mobile Data and Wifi off, Auto Sync off and Time out all the way down and your Bluetooth off.
Those steps helped me save a lot of battery. Hope this helps.
Hey you can try getting a battery saving app some are free and some cost money. Sometimes samsung can send you a dud battery its happened before you can contact them to give you a replacement.
I already suggested Easy Battery Saver which is a battery saver app
