Help battery life help??
13kellywu
Hi I just got my s3 and I noticed that the battery is drainjng realy quick (when I'm surfing the web and also when its idle). The battery drains >7% when its idle. I have power saving mode on, brightness to the lowest level, disabled sync and such. Is there something wrong with the battery?
And one more thing- the battery percentage is currently 70% but when I click on battery, it says 2 hrs and 17 mins on battery. How is this possible??
Thanks!
How long does your battery last before you have to charge it. Surfing the web and the screen can be a big battery drain. If you can post a screen shot of your battery stats after it has run for 6 to 8 hours some one may be able to help narrow some things down.
